Drawing sheet copy
MarcoLoli
Drawing sheet copy
Hello to everybody, I need your help. I would like to know if there is any possibility to copy a complete sheet of a Proe drawing to another sheet of the same drawing. Thank you! Marco
Hello Marco, Try this Open new drawings, Go to Insert-> Shared Data-> From File... Open the required drawings, it will be done Thanks, Sujay
MarcoLoli
(To:SujayKumar)
It works thanks a lot. Do you think that it will keep any reference with the drawing that I insertes as shared data? Thanks..
