I'm (happily) getting back into CREO (version 10) after a 5 year stint in SW.
I have to create new drawing formats and templates to reflect changes we've made to our title block over the years.
I have my C-size format and template working well. Is there an easy way to save as to other sizes and keep my title block and all parameters?
The easiest way to create new format files that I found was to save the table(s) and then to load the tables from file in the new format.
The issue you get when going from C-size to a larger size is the default font size changes.
I save all of my tables for C and D sizes formats with the size in the name then apply them as needed for the other sizes that use the same size letering.
