Drawing sheet format - Save as
HBreton
I'm (happily) getting back into CREO (version 10) after a 5 year stint in SW.
I have to create new drawing formats and templates to reflect changes we've made to our title block over the years.
I have my C-size format and template working well.  Is there an easy way to save as to other sizes and keep my title block and all parameters?
GabrielZaha
(To:HBreton)
The easiest way to create new format files that I found was to save the table(s) and then to load the tables from file in the new format.
GabrielZaha
(To:HBreton)
BenLoosli
(To:HBreton)
The issue you get when going from C-size to a larger size is the default font size changes.
I save all of my tables for C and D sizes formats with the size in the name then apply them as needed for the other sizes that use the same size letering.
