Drawing template views alignment
sparulekar
Hii!!
I want to create drawing templates using 1st angle projection method. I tried to make the templates but the views are not in alignment. How can I align them?
I am using creo parametric 3.0.
hi, there
draw a line first, then click template view. after you insert the general view, you can double click it to choose edit-placement by vertex. so that you can move the template views to the vertex. you will get views aligned.
Good luck.
Claude
2 REPLIES 2
hi, there
Good luck.
Claude
sparulekar
(To:claudedubois)
Thank you for your response!!
