Drawing template with shown dimensions placed in particular views
jhengel
Hello all,
I am trying to create a drawing template with 3 planer views and to show all dims. The only problem is that with show all dims, the dims show up all bunched up in one view. Is there a way to show all dims in there appropriate views?
Thanks for your help!
John Hengel
MCAD Admin
NIF - National Ignition Facility
Lawrence Livermore National Lab.
(925) 422-7608
John,
Yes this is possible but you have to calculate the position of the dimension yourself. It's not trivial but I have some (lengthy) code that will place the dimension based upon the outline of the drawing view. It's not perfect in every case but it is MUCH more clean that just showing the dimensions.
Patrick Williams | Engineering Systems | Sr. Applications Engineer | Steelcase Inc. | 616.698.4078
[cid:image001.jpg@01CA35E1.28026600]
