Drawing with Multiple Sheets
NEALROSENBLUM
Hey Everybody,
Is there a way to scroll through a multisheet drawing without having to explicitly click the various tabs at the bottom of the active window to view a particular sheet. I remember in Wildfire 4.0(?) how i was able to select a left or right arrow to easily navigate throught multiple drawing sheets.
In Wildfire 5.0, there are arrows but the arrows move the ribbon of tabs from left to right, but thisdoes not put you on subsequent sheets. Only after you see the sheet of interest in the tab ribbon can you select the sheet of interest to activate that particular sheet.
Also, my current drawing has about 20 sheets, but only about 10 tabs show at any given time (I named the various tabs so some of the tabs have alot of text). Is there any way to show 2 or 3 rows of tabs? Or am I limited to show only one line of tabs?
TIA.
(Wildfire 5.0, M060, Dell Precision M6600)
Sincerely,
Neal Rosenblum
Geometrix Engineering, Inc.
201 N. 13th Avenue
Hollywood, FL 33019
Ph: 954-920-2049
Fax: 954-920-9574
Cell: 954-649-9399
On 03/13/14 08:13, Neal Rosenblum wrote:
> Hey Everybody,
Try these mapkeys:
!next sheet
mapkey sn ~ Command `ProCmdDwgGotoSheet` ;~ Activate `gotosheet` `Next`;\
~ Activate `gotosheet` `Close`;
!previous sheet
mapkey sr ~ Command `ProCmdDwgGotoSheet` ;~ Activate `gotosheet` `Prev`;\
> this does not put you on subsequent sheets.  Only after you see the sheet of interest in the tab
> TIA.
> Sincerely,
> *Neal Rosenblum*
> *Geometrix Engineering, Inc.
> *201 N. 13th Avenue
> Hollywood, FL  33019
> Ph:  954-920-2049
> Fax: 954-920-9574
> Cell: 954-649-9399
> - <">mailto:->
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
>> Hey Everybody,
> Try these mapkeys:
> !next sheet
> !previous sheet
You can also doubleclick the sheet name ie "SHEET 2" OF 3 to bring up a dialog in which you can do
Previous, Next, or simply enter a sheet number. This dialog stays up until you specifically close it.
>> TIA.
>> Sincerely,
>> *Neal Rosenblum*
>> *201 N. 13th Avenue
>> Hollywood, FL  33019
>> Ph:  954-920-2049
>> Fax: 954-920-9574
>> Cell: 954-649-9399
>> - <">mailto:->
> Randy Jones
> 1525 E North St
> PO Box 5060
> email:-
> Phone: 785-823-3276
>    Fax: 785-667-2695
Randy Jones
1525 E North St
PO Box 5060
email: -
Phone: 785-823-3276
   Fax: 785-667-2695
