Drawings and flat patterns
cenglish
3-Newcomer
I would like to have a single drawing with both the flat and formed part on it. The first thing I tried was creating a simplified rep with the flat suppressed. When I go into the drawing, View States, simplified rep is greyed out and I can't select my rep with the flat suppressed. Another thing is that my assemblies were built before the flat and simplified reps were added so my assemblies blow up.
What is the best way to do this?
Flat patterns are always the last feature in a sheet metal part. I try to use unbend and bend back instead. If flattening forms is not required, I can use a bend back as a last feature and have a simplified rep for the flat part.
See here: Creo 2.0 Sheetmetal - Simplified Reps for flat pattern drawings
Don't overlook combination states. This is another way turn off features in drawings.
6 REPLIES 6
cenglish
3-Newcomer
(To:cenglish)
After posting my question, I found the solution in this thread:
Don't rely on the flat pattern version in the video. It works for Creo 2.0 but they seemed to have fixed it in Creo 3.0.
Funny thing is, if you created it in Creo 2.0, it will open with the bend back below the flat pattern feature, but you cannot do this in Creo 3.0.
Don´t scare me please... Is it really fixed in Creo 3.0? Bend back can´t be after flat pattern feater?
This method is our "company standard" method...
Using Creo 2.0 M120 and waiting for Creo 3.0 M040 ....
AndyHermanson
(To:mbonka)
I was looking into this as well and as far as i can find, this is "fixed" in Creo 3.0. I was really disappointed as well.
Create an instance and use that in your drawing by using "add model" After you create your flat you can create an instance by clicking on the drop down arrow next to it (just click through and use the defaults). The picture shows it greyed out because it is already done, The flat stays suprressed in the model. Much easier to use no bend/unbend or simplified reps. We always dedicate the last sheet for flat patterns, makes it easier to export as a .dxf to the programers.
