Dual Dimension Decimal Places
gkemner
7-Bedrock
I am unable to set and control the number of decimal places of dual dimensions on a drawing.
I can change the decimal places of the primary dim easily but it has no impact on the secondary dims. I want the secondary dim to have 2 decimal places even if it is an even number ie 6.00 Right now I have 3 decimal places for the primary but if it is an exact number for the secondary dim all I get is 6 with no decimal places.
I have the drawing option set:
dual_digits_diff -1
WF 4.0 M170
Windows 7 64bit
Thanks!
1 REPLY 1
Have you tried:
The drawing setup file option "lead_trail_zeros" controls the display. The proper values are:
	std_default	English dimensions will show trailing zeros and metric dimensions will show leading zeros
std_metric Dimensions will show leading zeros regardless of model or drawing units
std_english Dimensions will show trailing zeros regardless of model or drawing units
both Dimensions will show both leading and trailing zeros regardless of model or drawing units
In Reply to Greg Kemner:
dual_digits_diff -1
WF 4.0 M170
Windows 7 64bit
Thanks!
