Hi All,
I know this might be a silly question, but I need your help over here
I want the dual dimensioning to be active, whenever I open the new drawing. But unfortunately that is not happening, instead I'm changing the "dual_dimensioning" value to "primary[secondary]" each time. which I feel time consuming. One of my friend suggested me to write the configuration file.
But it was of no use
. Guys its a bit urgent, please help me over this.
Yogesh
There are two ways; drawing templates with everything preset or a detail.dtl file the way you want it.
This is the config.pro option to have Creo use your file:
drawing_setup_file <drive>:\<path>\<filename>.dtl
Yogesh,
what software do you use ?
Martin Hanak
Hi Martin,
Its Creo parametric 2.0
Yogesh,
Martin Hanak
Martin,
I did what you said, but it is not really working out,
I'm fedup with this, for each and every drawing I've to keep doing this
Yogesh,
please send me your config.pro, dtl file and shortcut properties (see my picture for inspiration).
Martin Hanak
