EXTERNAL: show some hidden lines in drawing
mathew.palazola
2-Explorer
Yes... you are correct... some other users pointed me to this as well.
The only problem I STILL have is that this works for the "true" edges of the tap-drill, but does NOT work
for the "silhouette" edges for the thread major diameter, which is just a surface, and major diameter bottom/end.
It's not a layer issue I have, I unblanked all layers... still no luck.
Thanks to everyone for their input and help
Matt
1 REPLY 1
When I've run into this in the past I would just make a either a breakout section on the main view or a section view of the area while leaving the main view set to 'no hidden'.
In Reply to Mathew Palazola:
Matt
