Is there a way to edit the position of several parts, in several explode views at the same time?
I have an animation of a complex assembly, and if i want to edit the position of some models, i have to go edit all the explode views mannually?
Thanks!
Hugo,
Editing of components in explode will apply to active explode state only, no option to edit in multiple views at a time.
The level of effort required to set up complex exploded views is significant. I have completed a single exploded view before copying the assembly and drawing to its other 3 variations.
If you are doing what I think you're doing, you have a sequence of events exploded out and the prior is dependent on the next.
...or something like my first scenario where you have multiple similar products to explode.
Anyway, you are out of luck until you become a guru in the view manager. There are some helpful tools if you understand the options.
