While in wireframe view, editing a hole and trying to rotate the model, creo creates an Windows 3.1 mystify screensaver feel. Zooming in and out will fix the issue. Does anyone know how to prevent this? Editing a hole feature while in wireframe and moving the model.
This seems to be related to graphics.. you may try updating the graphics drivers..
Try the same without any config files.
BTW, which version of Creo are you using? and share some machine details..
great, check if there is any config for graphics or try splitting the config to find the one creating this issue.
Don't forget to mark your answer as correct for those who may search on this topic in the future.
Will do.
