Editing parameters with Excell.
FrancescoPompeo
Excell is a standard, editing parameters with Excell will be easy and it could be the best way to Export/Import them.
4 REPLIES 4
solidworks used excel, since 2001, there is a SPR for Reordering family table..
All 3 of these Product ideas are similar and each should be voted for to increase chance of implementation:
http://communities.ptc.com/ideas/1202
http://communities.ptc.com/ideas/2203
http://communities.ptc.com/ideas/1542
(clicking link does not work so you need to copy/paste into browser address bar)
It would also be nice if the entire table size could be scaled bigger or smaller (text boundaries and all).
Lawrence
"When you reward an activity, you get more of it!"
  FRIEDER MUELLER 05.05.2014 23:55
Very good idea,
I would like to add that reordering of rows and columns should be possible via drag & drop
AND:
Dont forget to vote for fixing the insertion of links:
http://communities.ptc.com/ideas/2622
from above
Thanks, Frieder
Keeping this open for voting; it is related to, but not the same as Add Excel functionality to Tables in Creo Drawings
Best,
Toby
