is there a way to specifically search for elements without children and list them all up? This would really help with cleaning up the part. It would probably be best to delete unused elements right away, but in reality that's not going to work all the time.
Regards, Patrick
Yes you can use the find tool for this. You have to pick a parent reference. In my case I picked the default CSYS:
