Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
It's been a number of years since I've done this and have apparently forgotten the method.
How do I get a symbol (like the standard surface finish symbol) embedded into the body of a note. With dimensions it's done using &d123. I know it's something similar to that.
I am busy with preparing the introduction of using drawing templates. I am defining the drawing template by creating a new drawing, selecting application "template" and select the format I want to use. I use the format file, which we use for creation of the drawings inclusive the automated table with standard parameters. (&scale, &drawingname etc.) Also a drawing view is placed in the drawing template.
The problem I have is that when the drawing template is used for creation of the drawing the parameters are not functioning anymore in the table. Is anyone able to help me out? Thanks in advance.
With kind Regards,
Bert Busschers
Sr. Mechanical Designer/CAD Administrator ME/ID Department
