Embedded Dimension problem
EricHuffman
2-Explorer
Gurus,
I'm trying to add a dimension in another dimension using the following
syntax
3x &d280 = @D
The value for &d280 will only show on model dimensions; however, I want
to show it in a dimension created in the drawing.
I'm pretty sure I have done this before so I wonder if it is a config
option or drawing option I need to set.
Any ideas?
Eric
Wildfire 4.0 Datecode m090
Windchill 9.0 Datecode m030
Eric
1 REPLY 1
Look for the config option 'create_drawing_dims_only' and set it to
'no'.  This controls where the created dims in a drawing are stored.
Yes - created dims are stored in the drawing, No - They are stored in
the model.
Selecting 'yes' means a change to the drawing doesn't generate a change
to the model, however it prevents embedding model dims (& parameters I
believe) into created dims.
Doug Schaefer
LinkedIn
