Embedded picture in Drawing
uavron
Hi Everyone,
This is an old bug revisited.
In earlier versions of ProE, when saving a drawing with its picture embedded (config option: save_drawing_picture default value:embed) we sometimes ran into a very troubling issue.
In several cases, especially when dealing with big drawings, even if the 3D model was changed, the change would not show up in the drawing until all the views in it were intentionally updated by using the menus View->Update Views
If the user forgot to update the views, the printout of the drawing was also out of date and it caused quite a lot of headaches.
As far as I remember, I have seen this problem last with WF2.
My question is whether someone has encountered it with WF5 (Creo Elements/Pro for the picky ones...:-)) and/or Creo1 or can we declare that this bug is extinct?
Thank you all in advance
Uriel Avron
Harmonic Systems Ltd.
0 REPLIES 0
