Warning message upon opening STEP file: "Could not construct feature geometry"
The above message does not confirm that there is no geometry defined in the STEP file. Have you opened the STEP file in a text editor to see if it lacks geometry definitions? If the STEP file has geometry defined in it, then this could indicate that Creo is not able to interpret it to create geometry when you are importing it. Exporting from Creo does not guarantee that it will come back into Creo without errors.
More information would be useful to determine the issue. Provide some more context on exactly what you have done or post the models for review. If you are unable to post models, then upload some pictures of the models and the model tree that are relevant to the issue.
Sorry for the late replay. The compressed zip file is attached. This problem only occurs when the model is build with multibody part design.
Hello @pwyka
Could you share some details about testing the issue? I tried creating a step file for assembly you shared but that exported well for me.
Thanks.
