Hello every one
I´m working on an assembly and I just finished it.
A co-worker renamed a sub-assembly and now it shows this error "file name changed, not checked out by you".
I can do check in and check out to my assembly, but I am asked to remove that error. Thanks in advance for your support and kind response.
It may be as simple as gong to the workspace and using Tools - Synchronize
It was a strange problem for me because it was an assembly that wasn't even in my workspace before opening it.
Then I synchronized it but it still didn't fix the problem until I erased everything in my workspace again, erased not displayed and then reopened it again. Finally it went away. At this point I wish they made it more user friendly like Solidworks. When I used Solidworks I thought it sucked but now I realize the value of what I have lost.
