Error opening schematic file version 8
MS_Santos
I have an error when I open some files on the network with a very long path in Schematic 8, the same error as follows print Schematic_2, in Schematic 4 the same file opens normally. Then when I open the file in Schematic 4 Schematic 8 stops working is there any solution for this?
MS_Santos
(To:VladimirN)
Thank you very much, already open and support has already contacted
You're welcome.
