Hi All,
I'm working on a Quick Table to show a Assembly BOM and I have some components that I don't need to show on table, does anyone know if this item can be excluded in th Table?.
Thanks in advance.
Omar,
You can exclude the components in table using, Table > Repeat Region > Filters > By Item > Select component in table to exclude > Ok > Done
Omar,
