I was working with exploded views that can be pulled from the subassemblies to the parent using the default explode. However the explode lines from the subassembly are not showing in the parent. Is that how its supposed to work or am I missing a setting that can bring the explode lines into the parent?
Hi @ZC_10909252,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
