Export Creo harness as step file
avi_sharma
6-Contributor
I'm trying to export Creo harness as a step file and while it was working fine half way through, now that the harness is complete I'm not able to export all the cables in step file.
I've tried iges also and the same cables are not exported. Am I doing it wrong or is there a limit to number of cables you can export?
Also, if there is any other format that can export Creo harness and allow it to open in Catia please let me know.
Avi
Chris3
(To:avi_sharma)
How are you doing the export and what is the intent? Is it for visualization purposes only?
When I have done this in the past I have exported as a step with surfaces turned on instead of solids and its worked without any issues.
汐xie
(To:Chris3)
Yes, it is working well to export harness part as surface (no solid)
Please check the picture which was done in Creo 4 M060.
