Export Technical data
dgarcia
I have to investigate how to export technical data from my assembly to a external file (text, Excel...) with the following assumptions:
* My product is configurable. I may have to remove some compoennts and add others.
* My product can have different positions. For example, I need center of gravity in different positions
I know how to add / remove components with Pro/Program
I know how to get movement with Mechanism or skeletons
"Inteligence" could be done in JLink
It seems quite complicated. I thought I might ask if you have done something similar, and which is your recommendation.
Best regards
Daniel Garcia
5 REPLIES 5
What data are you trying to export? Mass properties? Parameters?
dgarcia
(To:dcaucutt)
We would export:
* Measurements
* Weight, x, y z position of center of gravity
I guess we would define some points here and there with "smart" names. Then we would have some program which would:
* configure the assembly (add and remove components)
* change position
* calculate mass properties and regenerate (to set mass properties data in place)
* return the distance between those points
You could write a map key to get most of that information. That would help make things go a bit faster.
You already know a lot more than I do but I thought I'd drop this hint:
Some of the 3D export formats have a checkbox for exporting parameters.
They do export by default and they can be read (ASCII) from the export file.
Not sure you want to parse 3D export files to pull a few parameters out of a model.
These would also require the parameters be created and regenerated correctly.
j-link is your answer.
