"Anthony Howard" wrote:
We are using Wildfire 4, hopefully Wildfire 2 also has this export option.
To get the.1 off just rename the file without the .1
your IT department has to make it so you can see it. It is not a creo option
I do it all the time. It's a windows function. Click on the file name in explorer and right click "rename" then take off the.1 at the end and enter..............done. Then do to a new excel and click file open and browse to the file. You man have to play around with the columns bringing it in. Too bad the excel sheet does not update when you change things in pro/e, with it did.
