Export asm view to dxf, using Wildfire 2.0 ?
g_fagioli
I would like to export from assembly view (to be chosen), to dxf format.
Is it possible ?
I'm using wildfire 2.0, and in "Tipo" pull-down of the "File/Salva Copia" command there is no DWG.dwg or .dxf extension available.
What step should be done ?
Thanks in advance for reply
4 REPLIES 4
Have you created your drawing sheet (".drw") with the required view? Then you can export them.
Many thanks VladimirN for your reply!
Can you give me a further help by showing the step by step commands required to create the drawing sheet ?
file/new/drawing and insert/view
Thanks for your valuable help !
Regards
