I would like to export from assembly view (to be chosen), to dxf format.
Is it possible ?
I'm using wildfire 2.0, and in "Tipo" pull-down of the "File/Salva Copia" command there is no DWG.dwg or .dxf extension available.
What step should be done ?
Thanks in advance for reply
Have you created your drawing sheet (".drw") with the required view? Then you can export them.
Many thanks VladimirN for your reply!
Can you give me a further help by showing the step by step commands required to create the drawing sheet ?
file/new/drawing and insert/view
Thanks for your valuable help !
Regards
