Many times each month I need to export an assembly for model making. All the model makers want are the solid surfaces. If they get a file with a bunch of misc curves and surfaces used in construction it is very confusimg for them. Typically I customize the layers and set them to skip export on curves and surfaces. The problem with this method is with large assemblies, where you have to go in and change each parts set of layers. It is too time consuming and easy to mess up. Often I export something I don't want or I skip something I do want. Is there a config option to just export solid bodies only?
