Our CADs specialists are currently running CREO 2.0 M220. They need to export file in JT format. We understand that this will require an additional license INTF_for_JT. Is that correct?
Moreover, we have also understood that in CREO 4.0 the interface for JT is already included in the baseline. Is that correct too?
I don't believe this is correct. I have Creo 4.0 installed and I do not have the option to save to a JT file.
Here is an article that seems to confirm this (even though not updated yet for Creo 4): https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS70279
