I need to export an assembly file as seperate STEP files. In the exporter options the option to seperate the file is misssing. How do i get it back?
I don't get any instance where I do not have the option to write individual files.
Is the source file an import into Creo as well?
What version are you using and do you want to share the file to see if it is something in the file or the system?
