Presently we use shrinkwraps for customers without many problems (except file size).
The method is as follows:
- create a solid part which fills the interior of the assembly (e.g. by using the inner sides of the sheetmetal housing) and assemble this as one of the first components
- hide or suppress any components You don't need
- save a copy as shrinkwrap with the following settings: merged solid, quality 3 (our parts are about 150 mm square), no automatic hole filling.
Sometimes it proves necessary to explicitly add some smaller components manually, but only because they have been missing in the result, not because the shrinkwrap fails.
This method has worked so far (Wildfire 2, M230)
