Extrude attached or unattached option
CAD_user
In Extrude command, There is this option, attached or unattached, I didn't found any utility for this. What's it intend?
In sheet metal?
http://support.ptc.com/help/creo/creo_pma/usascii/#page/sheetmetal%2Fsheetmetaldesign%2FYour_Design%2FAbout_Creating_Walls.html
A wall is any section of sheet metal material in your design. You can create two kinds of wall:
Unattached wall—An independent wall that does not need another wall to exist.
Attached wall—Dependent on, at least one other wall.
You can create these types of unattached wall:
Planar
Extrude
Revolve
Boundary Blend
Swept Blend
Sweep
Helical Sweep
Blend
You can create these types of attached wall:
Flat
Flange
Twist
Those are state of geometry preview within the feature creation user-interface.
Attached—Displays the geometry as it appears when you finalize the feature.
Unattached—Displays the outline of the geometry you are defining.
Config option 'dynamic_preview' controls the default preview state.
For better display, Create a solid box and on that create a hole. When creating hole use Attached or Unattached.
CAD_user
(To:Mahesh_Sharma)
So, it works only for the preview option
yes.
