FLOW E
JacobD.Pierce
FLOW E
So I'm trying to run an analysis of a wing(it's an assembly) through Flow-E. It is just a basic extrusion ibl i slapped together. Nothing special. I'm trying to run these to make sure software is working properly before RWDC hits off. I keep getting an error message say I have to have the "heat conduction in solids" option turned on.
is this about Creo Elements/Direct Modeling - FE Analysis?
If so - can you please add the error message / picture or even better - in case you have active maintenance - contact your local support center to get help.
If the product does not match the Creo Elements/Direct Modeling area - you might consider to ask this question in a different product discussion board.
