FOLLOWUP- Use JLink to modify a Pro/Program file?
lylebeidler
Thanks to Bjarne for pointing me to ProgramExortInstructions &
ProgramImportInstructions.
I was able to successfully export the program to a text file & manipulate
the file.
The issue I'm having is when I try to import the program file back into the
model, it fails. It appears as though the issue is with the dialog in the
message window, where Pro/E asks you "Do you want to incorporate your
changes into the model?"
How do I get jlink to answer yes, so to speak? It seems that would be
covered in the ProgramImportInstructions, but the api wizard is not giving
me much information there.
Thank you!
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
I forgot to mention - the message window displays
Use EDIT FROM MODEL, this listing is outdated.
I don't know if that helps or not.
Lyle Beidler
MGS Inc
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
Lyle,
In line 2 of the ProProgram *.pls file there is a REVNUM. This is
increased for every edit through Tools>Program...
The message you get could be because the REVNUM is less in your imported
program file than the current models in session.
I have tested a little further and have experienced massive crashes of
Pro/E when importing program files after editing. I have also had some
successful imports, which I am unable to reproduce at the moment Smiley Surprised(
Bjarne
Lyle Beidler <->
23-09-2010 15:21
Please respond to
Lyle Beidler <->
To
'Lyle Beidler' <->
cc
Subject
[proecus] - RE: FOLLOWUP- Use JLink to modify a Pro/Program file?
I forgot to mention – the message window displays
I don’t know if that helps or not.
Lyle Beidler
MGS Inc
Denver PA 17517
717-336-7528
Fax 717-336-0514
