Im creating XML file from the design in Creo Schematic, then importing it to the 3D design in Creo Parametric Application Cabling.
After locating the xml file to import an error appears "Failed to parse XML file"
This is because you've got the preview window open in Creo Parametric when you go to import the XML.
If you close the preview window before you select the XML you won't get this error.
thanks for the info.![]()
