Framework doesnt work, afx shows its enabled but when i start the application again it shows "EFX failed to load" framework option doesnt turn up anywhere .please help me sort out this problem and suggest me so that i can work with framework
il be thankfull if this problem gets solved by anyone ![]()
Make sure while installing Creo you checked Advance Framework to be installed and have the license for framework in Creo.
If it was not installed, you need to install this from installtion media.
Thank you
this is a beautiful site to share knowledge ![]()
I thought this would work but this doesnt make the framework option work again even after re-installing the software please help me atleast how to start framework i would take it from there
Ok, I think you passed step one about installtion of Creo with AFX. Now check the license, you should have license for AFX. If you have license,
Execute reconfigure.exe from Creo2.0\Parametric\bin
Next > Next > Customize > Command Configuration > Edit > Move Advanced Framework to right and complete the installtion.
everything went right upto the edit option but the advanced framework option didnt show up.. would you help me with this sir? what might have gone wrong? my installation process or anything?the image is what i can see i cant find AF. please help me sort this out ![]()
Thank you Mr.Mahesh Sharma finally got what i needed thank you so much ![]()
