Family Tables - deleting instances
SteveJI
Hi all,
Is there anyway that all the existing instances in a family table can be deleted without having to open up each generic prt  in Creo?
tbraxton
(To:SteveJI)
To delete an instance, delete the row that contains the instance.
The only method in the UI I am aware of to access the row of a family table is done in the generic model where the instances are defined. I do not think it is possible to delete an instance an using the UI without opening the generic model.
The only option I can think of would be to modify the instance index file using one of the APIs if that is supported (which I doubt).
If you wanted to overwrite a large number of instances in a table you could import a table with a single record, I have not tried this. It seems like it should work but you would still have one instance when doing this.
Involute Development, LLC
Consulting Engineers
1 REPLY 1
tbraxton
(To:SteveJI)
