Family table of a part-configuration
I have a question regarding tables. Basically the tables don't work as I would like them to work. To be specific, I wonder if there is any way to set them up in the way that configurations work in SW.
Example:
I put a table driven screw with length 35mm in an assembly. I mate the screw. For a million diffrent reasons, a lot of times I need 5 mm longer screw. So what I need to do in Creo, is delete a the 35mm screw, open (open and assemmble) my generic part and choose 40 mm long screw, and than mate the screw again. I could just open 35 long screw, offset it 5 mm and rename it, but: i would mess my family table and i do double work again, so that kind of beats the purpose of family tables right? Why cant I choose the lenght /configuration/version (or however you wanna call it) of the screw within the part, so i would not have 'call' the screw in the assembly and re-mate it all over again?
Another example would be next: I pattern a part 5 times along a linear direction. Then i extrude a hole in the part. But I dont want the hole to be on all 5 patterned parts, i only want the extruded hole to be on first and fourth part. Is this possible without renaming the part under another name and then mating it on fisrt and fourth position?
Thank you for you help
