Is it possible for a motor to perform only half a rotation?
ioluyemi
Hi! Does anyone know how to get a motor to rotate with only half a rotation in Creo Parametric 3.0? I had tried applying constraints such that the rotating part could only perform half a rotation but anytime I tried applying a servo motor to run mechanism analysis, it would give an error message saying "Assembly failed. Constraints could not be satisfied". Is there any way at all that I can achieve half a rotation with a motor at a specific angular velocity?
I don't recall the specific options, but I believe there are controls for both time and angular limits that can be applied.
See Creo Parametric Help Center Mechanism Design and Mechanism Dynamics > Mechanism Dynamics > Analyses > To Enter Motor Information
Thanks so much! That link totally solved my problem
