I created 4 triangular sheetmetal parts (2 parts, 2 mirrored parts) with a flat wall bend at one side. These triangular parts are then assembled onto a bracket at the 4 corners. On the assembly level I cut out bolt holes into each triangular part (1 cut has all the holes). Then I put the fasteners in, define a preload, etc. I'm getting this error:
"The fastener references are not oriented correctly. This happens if the associated surfaces are not oriented such that the normal of the top reference surface points away from the normal of the bottom surface."
The thing is, I'm only getting that error on the mirrored parts, not the original parts. The references shouldn't change, and I've redefined the fasteners twice. Can anyone shed some light into what that error is telling me? It's not very intuitive, considering the faces of the two surfaces involved are parallel.
mike
The error description ended up not having anything to do with what was causing it. Mechanica wouldn't mesh a sheetmetal part, and so the fastener was being defined on a surface that didn't technically exist in the mesh. Not sure how that has anything to do with the error it threw but the problem has been resolved
Thanks for posting! So what did you do? I have the same issue but it's on a part that previously meshed and ran but now is giving me issues once it's added as a subassembly to a larger one.
