Fasteners references edges definition error
tleati
Hallo,
I have a problem with defining fasteners idealization in Simulate (Creo 2.0 M110).
I have to define a fastener between two components, when I select the two corresponding edges, this error message appears:
I suppose this errror is due to the fact that those are planar (in the sense that lie on a plane) but the visible one is not on a surface, but it's the end edge of the bolt hole:
the question is, can I define in some way an idealized bolt for this case without having to add material (otherwise it would be convenient to directly add the bolt itself)?
thanks
bye
10 REPLIES 10
Tommaso,
Try adding a surface region or volume region where the fastener bounderies are.  This will give you a valid flat edge / line on the cylinder surface to select.
Hope this helps
Don Anderson
Hi Don,
I tried with a surface region in simulate but it can be created only on already-existing surfaces. In paametric instead, if I create a surface just inside the edge, in simulate it is not recognized and the error message still appears. With a volume region how can I do then to define the bolt?
thanks
bye
Tommaso,
I was incorrect, you can use my approach for the end of the screw but not for the head.
You will need to use Mats suggestion or model the fastener as a solid and use the preload feature.
Don
Don Anderson
No time Like the Present!
Hi Donald,
thanks for your reply.
bye
When I encounter problems like this I model the bolt using a beam element that I attach using  weighted or rigid links at the beam endpoints. Create a surface region for the bolt head/nut mating surface, as the independent side of the link. The pre-load i create using a zero coefficient of thermal expansion for "the rest" of the model. The bolt/screws are modeled with a large coefficient of thermal expansion. Then I prescribe a "-1 degree" global temp load. The bolts then contract. I can tune, either the coefficient of thermal expansion or the temp load to get the pre-load that I wan
Unfortunately beams can't be used in large deformation analysis, even though the beam itself does not undergo large deformations, other than "rigid" body motion.
Hi Mats,
thanks for the tips,how you define a beam? with a curve between the two points in parametric and then you define them as beams in simulate? or this can be done directly in simulate selecting the two points?
bye
I typically create a point-point beam, from hole center to hole center. And yes, you can create the datum points in creo simulate, either on the top level, or on part level. If you create datum points on part level, in the creo simulate environment, the points end up as "Simulate features" in the model tree for that part, and are only visible in the simulate environment.
This technique is useful when the prerequisites for the "fastener" are not fulfilled, for example non-circular hole, or the surface might not be planar or parallel.
/Mats L/
ok thanks, yes in fact the beam I think is maybe the best way to work around the problem, as it it the same as the fastener (or even better maybe, I don't know if the software considers also the bending with the function fastener, while with a beam it does...)
bye
This is why I like using beams, you have full control, and you can access/control what d.o.f.'s that you want to activate/deactivate through beam releases, etc. Fasteners act a bit like a "black box" and you don't know what's going on...
Hi Mats,
How do you prescribe temperature boundary conditions on beams or on the whole model in Creo Simulate 3.0?
Best Regards
Andrea
