Hello!
Please help with fatal error.
Occurs in various situations (sectioning, hiding components, view settings).
Traceback as an attachment
Creo 5.0.4.0
in the past I met such situation. It was caused by graphic card drivers.
1.] Add following option at the end of config.pro file and test Creo behaviour. If the problem disappears then you know that it is related to graphic card drivers.
graphics win32_gdi
2.] Remove anove mentioned option from config.pro file and install current graphic card drivers.
graphics win32_gdi
Thank you! I'll try this method
