Fatal Error in a drawing when choose axis as a preference
Hozaibergen
I experienced the following unexplained error. I have a drawing of a part with holes, and when I want to put a note with a leader or create a dimension by selecting the hole axis as the reference, the program gives a fatal error
Moreover, if you make a new hole in this model and select its axis as references, everything works
I think the solution to my question is here (CS273123), but I don't have a valid subscription
(Creo 5.0.4.0)
StephenW
(To:Hozaibergen)
The support article defines it as a bug that was fixed in creo 5.0.0.0. It shouldn't be a problem in 5.0.4.0
No info other than closed with a software fix.
Your issue probably isn't a bug, it's probably a data dependent error, especially since a new hole axis doesn't exhibit the same problem.
5 REPLIES 5
StephenW
(To:Hozaibergen)
Thank you!
Hello, Stephen
Maybe the answer is here  https://www.ptc.com/en/support/article/CS123507
StephenW
(To:Hozaibergen)
That one also shows as a bug fix. It wasn't a fatal error exit,
"note is displayed as expected, but leader is not visible"
  • Resolved in :
    • Creo Elements/Pro 5.0 M190
    • Creo Parametric 2.0 M060
    • Creo Parametric 3.0
  • Workaround: Access >Review >Update Sheets
One more nuance.
If I make a new drawing of this part, and refer to the axis in the drawing, everything works
