Fatal error crashes with CREO parametric
JS_8716467
2-Guest
I am using Creo Parametric Release 2.0 and DatecodeM250
CREO crashed unexpectedly
Fatal error encountered. A traceback has been written.
We had several cases with crashes.
jchelle
(To:JS_8716467)
Hello ,
Creo Parametric 2.0 is out of maintenance: no more supported and developed.
Nevertheless you can find some guidance at article CS31618 .
Best regards
Jean-Claude
jchelle
(To:JS_8716467)
Hello ,
Best regards
Jean-Claude
Thanks for your reply.
I know CREO 2.0 is no more supported but as we cannot update the version now, I try to solve main issues.
We will check the CS31618.
Julien
