Feature recognition
ptc-2936191
Feature recognition
How do you install feature recognition?
1) Unzip the files in one folder; 2) Change the path in frt.dat to point the path which you have copied the files; 3) Open ProE 4) Tools\Auxiliary Applications; 5) Click Register; 6) Point to frt.dat; 7) Select the FRT line; 😎 Press Start; 9) Enjoy! if you have any doubt, please ask again. José Martinho
Thank you!
I reinstalled wf 5.0 64 bit, does someone have a feature recognition link for the 64 bit version?
TIA
John
It should be included with WF5. You do need to set the config.pro option frt_enabled.
