any buddy guide me how to fill, merge & solidity attached surface file.
kind regard,
If you think your question has been answered, please choose a answer as "Correct Answer"
There are severl ways. Do you need something like this?
yes
There is no one click operation in Creo to do this. Since the curves are tangent, you can't use a boundary blend to close the open edge.
The usual process is to build some curves and then create boundary blends.
If you have the style module, then, you will have more tools available.
Another option starting in Creo 3 is the Freestyle tool. Take a look at the video.
Jose
Hello Sir,
Thanks a million for help. Please see the attached file I will done but can't work on boundary blend just like you mention in video can you check where I am wrong?
Kind regards.
I attached Creo 3 file.
Pay attention to the number of chains you select when creating a boundary blend, that´s the key.
Jose
Sir,
I was send e-mail on your profile ID can we extend solid part if we want?
Sir,
I am trying to tired but can't done please see the video link.
Kind regards,
https://www.youtube.com/watch?v=povNNRMXL4w&feature=youtu.be
It seems you have to do some tutorials...
Yes can you share yours video?
I mean you have to do BASIC tutorial. In your video you made mistake because you have to create a boundary blend with three curves. One of these has to be composed of two edges. Use SHIFT after selecting first edge.
Still same can't![]()
If you watched my video, you can see that I selected 3 chains to create the boundary.blend.
In Creo hold Shift to append curves to current chain and Control to add a new chain.
So, step by step:
1 - Click on boundary blend button
2 - Select first edge (This is first chain)
3 - Hold Shift and select the adjacent edge (added edge to first chain)
Be careful in this step to not select all open edges, it may happen.
4 - Hold Control and select the curve (Second chain)
5 - Hold Control and select another edge (Third Chain)
6 - Hold Shift and select last edge (added edge to third chain)
7 - Press Ok ![]()
This is it...
Jose
thanks a lot now i got the points
You can also try Style feature (if you have ISDX license): Surface tool -> turn on Options-> Trimmed Rectangle -> "Use for 3 or 4 boundaries".
This would create trimmed rectangle surface that are are looking for.
I'd recommend in your case to turn off default connections in Preferences dialog, to avoid automatic tangent connections which you don't need.
i can't see the video
i think ISDX will also work just fine.
