Fit component of an assembly to the screen
ysinitsin
Hello!
I'm stuck in one task in using J-Link.
I want fit the part to screen, which was selected by the mouse in the tree. Or, just, pan this part to center of the screen without zooming.
my code:
sel_options = pfcSelect.SelectionOptions_Create("membfeat");
selections = session.Select(sel_options, null);
SelItem = selections.get(0);
ComponentPath cp = SelItem.GetPath();
Transform3D tr3d_part = cp.GetTransform(true);
View vw = session.GetCurrentModel().GetCurrentView();
Transform3D tr3d = vw.GetTransform();
//Get origen of the selected part
st.SetZoom(1.0);
hPan = scale_x;
double vPan = scale_y;
st.SetPanX(hPan);
st.SetPanY(vPan);
cur_wind.SetScreenTransform(st);
cur_wind.Refresh();
The code are working not bad, if Zoom is 1. But if the Zoom <> 1, then the selected part fly out from the center of the screen.
I noticed that if the Zoom != 1 then PanX=0 and PanY=0 it is not a center of screen, as in the case of Zoom = 1.
Any help?
5 REPLIES 5
FV
(To:ysinitsin)
Hello all,
Yaroslav,
Those are transformations which one would have to apply to get a point expressed in terms of the inertia coordinate system to be shown at the center of thePro/E window.
Let's say that the screen center point is at {500.0,400.0, 0.0} ( screen coordinate system) and view to screen transformation is identity matrix {{1,0,0,0}, {0,1,0,0}, {0,0,1,0},{0,0,0,1}}
-get selected component
- gettransformationfrom component to assembly coordinates
- get selected point in component coordinates
- transform point to assembly coordinates
- get view transformation
- apply desired window scale to theview->screen transformation
- invertview->screen transformation
- transform point from assembly coordinates to view coordinates using view transformation
- transform screen center point to view coordinates using invertedscreen->view transformation
- calculate displacement from point to screen center in view coordinates
- transform displacement vector from view coordinates to screen coordinates usingview->screen transformation.
- add the displacement vector to the displacement vector of the view->screen transformation
- apply view->screen transformation to the window
HIH.
Feliks.
In Reply to Yaroslav Sinitsyn:
Hello!
my code:
st.SetZoom(1.0);
hPan = scale_x;
st.SetPanX(hPan);
st.SetPanY(vPan);
cur_wind.Refresh();
Any help?
Hello, Feliks!
Thank you very much for the reply!But I still need some help.
What I do:
sel_options = pfcSelect.SelectionOptions_Create("part");
Transform3D component_transform = cp.GetTransform(true);
View vw = SelItem.GetSelModel().GetCurrentView();
Transform3D view_transform = vw.GetTransform();
I skip this step
Transform3D tr3d_inverted = view_transform;
tr3d_inverted.Invert();
pointonmodel= view_transform.TransformPoint(pointonmodel);
Point3D screen_center = Point3D.create();
screen_center.set(0, 500);
screen_center.set(0, 432);
screen_center.set(0, 0);
Point3D delta = Point3D.create();
delta.set(0, pointonmodel.get(0) - screen_center.get(0));
delta.set(1, pointonmodel.get(1) - screen_center.get(1));
delta.set(2, pointonmodel.get(2) - screen_center.get(2));
FV
(To:ysinitsin)
Hello all,
Yaroslav,
Pro/Toolkit has two functions:
ProWindowPanZoomMatrixSet()
which we are using toget/settransformationsbetween model view coordinatesand screen coordinates. Somebody with J-Link experience should pitch in ...
But what I'm seeing from your sampe - there are no calls to get and set screen transformations, there were only calls related to model-view transformations.
The step you had skipped sets the scale to view-to-screen matrix, you could leave it at identity state but it has to be used, ommition creates errors in the next statements - you are applying view-to-model transformations to ahard coded screen center point, insteadyou have to apply screen-to-view transformations to get screen centerpointmapped to view coordinates.
Another error is in displacement calculations, if you need to calculate a displacement vector (AB)from arbitrary point (A)to a fix point (B) the displacement vector AB calculated as A + AB = B; AB = B -A.What you are doing isthe opposite of this.
HIH.
Feliks.
Hello, Feliks!
What I do:
I skip this step
I think inside the JLink the equivalent functions are Window.ScreenTransformSet(), Window.ScreenTransformGet() where you can set the Zoom and PanX / PanY to your calculated values. Both are from pfcBase in the help pages.
To create your own ScreenTransform use
pfcBase.ScreenTransform_Create(/*optional*/ Double, /*optional*/ Double, /*optional*/ Double);
Best regards,
Eike
Hello all!
Feliks andEike, thank you very much for your help!
I got what I want. Maybe the result will be useful for somebody else.
My working code for J-Link:
public void FitToCenter() {
Selections selections;
SelectionOptions sel_options;
Selection SelItem;
ModelItem mItem;
Surface surfItem;
try {
//Get the assembly component path for the selected component
//Get random point in the solid
Solid sl = (Solid) SelItem.GetSelModel();
ModelItem itm = sl.ListItems(ModelItemType.ITEM_EDGE).get(0);
Edge ed = (Edge) itm;
Point3D pointonmodel = ed.Eval3DData(0).GetPoint();
Point3D screen_point = Point3D.create();
//Get the coordinate transformation matrix for the component to the assembly
//Transform the selected point into the coordinate system of the top level assembly
screen_point = component_transform.TransformPoint(pointonmodel);
//Get root assembly
Assembly rootassembly = cp.GetRoot();
//Get current view of the assembly
View vw = rootassembly.GetCurrentView();
//Get transformation of the view
//Transform the solid model point to screen coordinates
screen_point = view_transform.TransformPoint(screen_point);
//Set size of the screen
screen_center.set(0, 1000);
screen_center.set(1, 843);
screen_center.set(2, 0);
//Get current window
Window cur_wind = session.GetCurrentWindow();
//Get screen transformation
ScreenTransform st = cur_wind.GetScreenTransform();
double hPan = st.GetPanX();
double vPan = st.GetPanY();
double zoom = st.GetZoom();
//Calculation for new PanX and PanY
delta.set(0, ((screen_center.get(0))/2 - screen_point.get(0) * zoom)/1000);
delta.set(1, ((screen_center.get(1))/2 - screen_point.get(1) * zoom)/843);
hPan = delta.get(0);
vPan = delta.get(1);
st.SetPanX(hPan);
st.SetPanY(vPan);
cur_wind.Refresh();
} catch (jxthrowable x) {
try {
session.UIShowMessageDialog(x.toString(), null);
} catch (jxthrowable k) {
By the way, for PROTOOLKIT exist an example.
The sample code in the file UgGraphZoomAtPoint.c located at
/protk_appls/pt_userguide/ptu_graphics
I don't test this sample. But I see some difference in Pan calculation. For J-Link PanX and PanY represent the horizontal and vertical movement. Every increment of 1.0 moves the view point one screen width or height. But in sample for C, this calculation looks strange. Maybe, for J-Link and Toolkit need to use different technics.
Best regards.
