Flat /Recursive by rule in Repeat Region?
EileenTung
Hi Gurus,
scenario
Main.asm
|----- abc.asm (parameter Supply = B)
||-----a1.prt (parameter Supply = A)
| |-----b1.prt (parameter Supply = A)
|-----123.asm (parameter Supply = Z)
|----- 12.prt (parameter Supply = B)
|----- 23.prt (parameter Supply = B)
If I'm having 2 sub-assembly in a main assembly drawing, How am I able to the show out the components with parameter
Supply == B by a set Repeat Region Table? (auto BOM: i.e. without manually Recursive 123.asm and filter off 123.asm)
In a repeat region,I can filter a parameter by rule, can I recursive an assembly by rule too?
So that in the table content, only abc.asm, 12.prt and 23.prt will be shown.
WF3
Thanks in Advance.
E.T.
0 REPLIES 0
