Does anyone have a suggestion for unbending solid bends (or spinal bends) similar to the way it is done in sheet metal? I was hoping that using flattened quilts would give me the results I need, but it appears to distort the geometry upon flattening (actually I tried bending from flat, and then created a mirror of the flattened quilt to bend back).
I have a rolled channel with slotted holes which I placed in the formed state, and would like to create a flat form so that the holes can be punched prior to the rolling operation. If I can't find a solution I will need to go back to putting the holes in the part before the bend operation and iteratively positioning them to end up in the correct position post form.
Thanks!
Maybe taking a screen shot of your model and tree would help. There should be no reason you need to make the part in solid as opposed to the sheet metal functionality of Pro/E. In fact, I suggest that when dealing with a sheet metal part you do as little outside of sheet metal as possible. This helps promote a robust part that can be properly manipulated using the most different types of features availible in Pro/E sheet metal.
As far as the roll forming operation, is there a reason you cannot use the flange feature in sheet metal? If so, I remember learning about a rolling feature in the Pro/E sheet metal online course that could help you out. I can't remember the name of it off of the top of my head but can look it up if you are truely stuck.
Ordinarily I would do this type of action in sheet metal ... but this part is an channel, and is not compatible with sheet metal. I'll try to break down the problem a bit better:
I have a C6x8.2 channel I need to do the following to:
1) Roll to the correct form (no problems using either solid bend or spinal bend)
2) Put holes in their final position (no problems)
3) Bend back to it's original flat form (distortion issues)
4) Suppress the bend back and create a family table instance with the bend back active to show a flat representation of the part ... complete with holes in their pre-formed position.
At this point, the only way I can see to get the desired results is to put the holes in before the bend, and then have the bend suppressed in the family table instance ... but that introduces a lot of trial and error positioning of the holes, and is not as robust of a part if anything changes.
Thank you for all your responses. What I'm getting from this is that there is no way to flatten out a solid bend or spinal bend without distortion.
I chose not to use sheet metal for these parts, as it would be a more complicated work around, and would result in a part not representative of the material I am using. If only I had AAX and BMX, life would be complete! Ahh well, there are other things I can do to get the job done.
My answer is to put the holes in the pre-formed part with clever use of relations to automatically drive the position of the holes relative to the length of the part. Sketching a curve of the neutral axis gives me the developed length of the roll, so it is a simple matter of measuring the neutral axis curve length and input that number in for the length.
Thank you everyone,
Dustin Hase
