Flexibility of a component's sweep trajectory in an assembly
tleati
Hallo,
since Creo Parametric (my version is 2.0 M110) does not provide an immediate 3d modeling of fillet welds, necessary to calculate them properly in Simulate, I would like to make a flexible component representing the fillet weld, modeled with a sweep, with its trajectory following the contour of the component to weld.
I am wondering whether there is the possibility to set the flexibility to the trajectory so as to choose it directly with a chain line when assemblying the fillet weld.
I hope my question is clear, I enclose a print of my screen with the fillet weld assembled. In this case I used flexibility on all of the corner angles and the lengths of the straight sections, but this way it's quite long to set up each time and furthermore if I want to insert the curved section (the round on the plate in the figure) I lose much of the universality of this flexible fillet...
thanks
bye
0 REPLIES 0
